Is this any different from the one used on the 5 sp?
Will it work (if the bulbs indicating the gears are removed, of course)?
I have the pod/cluster out on 89 GT, and the 'Gear Indicator' bulbs are removed, and circular yellow-ish tape are over the holes, so you should be good doing the same.
I have the pod/cluster out on 89 GT, and the 'Gear Indicator' bulbs are removed, and circular yellow-ish tape are over the holes, so you should be good doing the same.....
