928 Forum 1978-1995
Sponsored by: 928 Specialists
Fuel pump age
Old 05-31-2020 | 01:01 PM
gazfish's Avatar
gazfish
Default Fuel pump age
Hi All,
Out on a drive and giving it a bit of gas coming out of a bend and the engine stumbled and lost power for second, my gut feeling is it’s probably fuel starvation. Reconditioned MAF, ECU, relatively new ignition amplifiers, spark leads, MAF connector, fuel pressure regulators etc. The only thing is today has been the hottest day of the year so my first suspicion was the fuel pump as I don’t know the history of it (new filter). I found age codes for Bosch filters and this had 066 as June ‘90 or maybe 014 is 2014? does anyone know if you can tell the age of a pump ?
New rubber mounts ordered by the way before you point it out, there’s only 2/4 attached.
The other unkown is the CPS which would be next on my list.
Thanks,
Gary
Old 05-31-2020 | 05:01 PM
vanster's Avatar
vanster
I have found that they are good for about 100k. Just replace it an and put that issue aside.
Quick Reply: Fuel pump age
