replacing B2 cover 0-ring on A28/16
chasing a leaking transmission on 89 Auto-A28/16
can the o-ring on the B2 cover be changed without removing the passenger rear exhaust?
Is the clip holding the cover re-usable?
Are these the correct part numbers?
CLIP 126-994-01-35
O-RING 005-997-70-48
Can the cap be depressed without a tool?
Is this possible without disturbing the B2 piston?
Any info on this procedure appreciated!
CLIP 126-994-01-35
It is probably possible, but would be immeasureably more difficult
Is the clip holding the cover re-usable? Yes
CLIP 126-994-01-35
Sorry part numbers are not available to me. Call Roger and he will send you the correct part.
Can the cap be depressed without a tool? Yes
Is this possible without disturbing the B2 piston? The piston can stay in place
CLIP 126-994-01-35
