I found this connector under behind the drivers side knee shelf. Just hanging out. It has 12v when the key is in the on position. If it should be connected where? Thank you.
MrMerlin
”do you have a connector plugged into the shaft between the steering column and the key switch? it tells the system that the key is still in the switch”
