No fuel to eng fuel hoses
So I started to start my 82 euro atm 928 after picking er up over the winter. car looks like it hasn’t been started for 10 plus years and left outside.
I dropped the tank flushed it out put a new strainer,pump and filter. I tried to start it to see if I got fuel to the front fuel lines but there bone dry. I here the pump cycle and the relay is working. The only thing it could be is the accumulator.Is it possible that it’s clogged solid and no fuel getting thru.
someone else was in there and put a hose with a bolt and clamp on the top I guess to stop a leak.
im going to attempt to remove the accumulator tomorrow but all the nuts are on there tight, is it possible to bypass the accumulator?
