Fried HVAC board
Fried HVAC board
I'm looking for a fried HVAC board and the only part that needs to be functional is the section of the board where the connector slides onto the board. Anyone have one cheap? or free?
They are double sided. I used them to build adaptors for my gauge cluster when I installed the lutz circuit boards. I have an 83 s by the way.
i cut a small slot in the end of the board and stripped enough wire to wrap through the slot and soldered on both sides. Then covered it all with epoxy once connections were made.
Definitely not pretty but functional and kept me from cutting the factory harness.
here is a link to the boards (I use them to build arcade games).
http://www.arcadeshop.com/s/1/c_finger.htm
and the pins inside the connectors
http://www.arcadeshop.com/i/475/mole...p-in-crimp.htm
