928 Forum 1978-1995
Sponsored by: 928 Specialists
door locking issues, again
Old Apr 6, 2020 | 05:10 AM
siscogts's Avatar
siscogts
Default door locking issues, again
Hi, I used search button, but given solutions do not seem to work for me.
SO...1992 GTS .
Doors closed .I use lock on left door, it unlocks itself, RIght door is locked .As per instruction I can turn 3 times the key into the lock to engage alarm and keep the door locked, but 1 led does not flash, after 3 times I can hear the lock motor moving, and I see the door locking pin moving slightly up, 1 mm or so...
I can lock the car using right door lock to "open/close (ad the right door pin led flashes) ,
when car is closed , using right door lock , I can unlock only the left door, the other door(presumably also the other locks) is still closed.
Theo J software seems to tell me everything is fully working.
any ideas?
I have time to spend, in quarantine days.
Thanks in advance
Francesco
Old Apr 6, 2020 | 10:17 AM
Mrmerlin's Avatar
Mrmerlin
Team Owner
is your car right or left hand drive
Old Apr 6, 2020 | 11:08 AM
siscogts's Avatar
siscogts
LHD
Old Apr 6, 2020 | 11:09 AM
siscogts's Avatar
siscogts
Update:
Now everything seems to work properly, just testing this and that, spraying grease here and there.
Eveeything but the led of driver door.
