928 Forum 1978-1995
Sponsored by: 928 Specialists
NO SPARK
Old Mar 22, 2020 | 04:23 PM
Cincinnati Kid's Avatar
Cincinnati Kid
Default NO SPARK
i've replaced the engine bay wiring in my 1982 928, and now when i go to start the engine there is no spark. there are 12 volts to the positive side of the coil. when i turn the key to start, the engine turns over and the negative side of the coil pulsates as if it is being triggered. a half second later the coil loses spark. i've switched coils and the exact same thing happens. any ideas or advice would be appreciated.
Old Mar 22, 2020 | 04:55 PM
Mrmerlin's Avatar
Mrmerlin
Team Owner
did you check the resistors at the fenderwell
Old Mar 22, 2020 | 05:54 PM
Cincinnati Kid
no i have not. are they ignition resistors? where on the fenderwell are they located?
Old Mar 22, 2020 | 06:17 PM
Mrmerlin's Avatar
Mrmerlin
Team Owner
https://rennlist.com/forums/928-foru...or-a-78-a.html
Old Mar 22, 2020 | 06:24 PM
belgiumbarry's Avatar
belgiumbarry
did you re-wire the ignition box connection ? there is a "weak" signal for the tach and a "strong" one for the coil ….???? or kept the oem wiring / connection ?
Old Mar 22, 2020 | 06:38 PM
Cincinnati Kid
i'll double check the connections. the oem wiring harness was so deteriorated that i couldn't tell one wire from another and where they ended!
