steering wheel replacement 928 GTS
hey I need some wisdom on which momo steering wheel hub adaptor to go with for proper replacement of my airbag wheel with a non airbag wheel ,I know there's a few steps involved ,any advice would be appreciated .
I have a 94 928 GTS renegade Porsche and its anything but stock ,
My post from a couple years ago might help: https://rennlist.com/forums/928-foru...l#post13653901
The adapter I cite fit my splines and the 928 Sport wheel. Not sure if it will work on whatever wheel you may be using though. Note that you'll need the "L" horn contact too and you also have to put a resistor in the airbag sensor plug--otherwise you'll get a "fault" that can only be cleared with a Hammer or similar device.
The resistor needed is 3 ohm. I bought a cheap one from Radio Shack (back when they were still in business) and it was not accurate enough. So I bought one from an electronics warehouse that had a much tighter tolerance, that worked fine and I never got the airbag light again.
