928 Forum 1978-1995
Sponsored by: 928 Specialists
Ljet crank no start NO spark
Old 02-29-2020, 06:18 PM
j.kenzie@sbcglobal.net
j.kenzie@sbcglobal.net's Avatar
Default Ljet crank no start NO spark
Hi guys
I have another thread about my thermotime switch, but I think this is probably a separate issue.
For the past couple of years my car, 84 US automatic, has been getting more difficult to start. I can smell gas after long cranking so I think I have fuel delivery. Jumped the FP relay, FP audible, but no change.
I checked the coil output to the distributor and I have NO spark. Checked with spark tester and timing light lead. Green wire was replaced 4 or 5 years ago. Coil unknown age. I will go through ohming out the coil lead and the coil itself, but any suggestions are appreciated.
Thanks,
Dave
Old 02-29-2020, 09:50 PM
Hi guys,
I have some data:
No spark at coil wire tested with spark tester and timing light
batt voltage: 13.2V
Coil measurements:
terminal 1 voltage: 1.7V
terminal 15 voltage: 4.5V
coil wire resistance: 1.1 K ohm
coil secondary resistance term 1 to 4: 10 K ohms
primary resistance term 1 to 15: 0.5 ohm
So coil seems OK. Will check green wire connections and distributor.
Thanks very much,
Dave
Last edited by j.kenzie@sbcglobal.net; 02-29-2020 at 10:27 PM. Reason: wrong reading on dvm
Old 02-29-2020, 10:05 PM
Rich9928p
Rich9928p's Avatar
The factory workshop manuals have an excellent diagnostic test flow for no spark in Volume 1A beginning at page 28-11. The manual can be downloaded at http://www.ligeti.com/928/
Old 02-29-2020, 10:26 PM
Thanks Rich,
I'm trying to use that exact test section. I will post additional data.
Dave
Old 03-01-2020, 12:05 AM
Mrmerlin
Team Owner
Mrmerlin's Avatar
Received 2,453 Likes on 1,378 Posts
You might need a new fuel injection relay,
your car has the compound relay
mkhargrove (04-03-2020)
Old 03-01-2020, 12:18 AM
Thanks, Stan. Can I jumper it, to test?
Dave
Old 03-01-2020, 12:23 AM
PorKen
Inventor
PorKen's Avatar
Check/clean the TSZ spark box connectors. Plug in a known good one to test.
hacker-pschorr (03-01-2020)
Old 03-01-2020, 12:27 AM
Thanks, Ken. This problem has been coming on for some time, consistent with building corrosion or gradual failure of ignition box. I'll be looking at it.
Dave
Old 03-01-2020, 09:12 AM
Mrmerlin
Team Owner
Mrmerlin's Avatar
Plug in your spare relay you do have a spare
Old 03-01-2020, 09:44 AM
Hi Stan. I do have a spare fuel pump relay, but no fuel injection relay. Never knew I'd need one. Can I make a three way jumper? My green wire is pretty new and I understand the ignition modules on these cars rarely fail. I'm looking for single component failure somewhere here. It looks like I have good voltage to the coil and the coil resistances seem OK. Sounds like coils rarely fail also. So I like the idea of relay, relay, relay...
Thanks,
Dave
Old 03-01-2020, 09:47 AM
BTW one of the drawbacks of a supercharger install is that it makes access to many components much more difficult. I will get there in checking the ignition module and green wire connections, but I have to remove some SC piping to do it. Just takes time. Also I'm working off a ladder, since the car is on a storage lift. I'm getting old too. I'm not complaining, just explaining why I might seem lazy and just want to check easy things first.
Thanks for all the help.
Dave
Old 03-01-2020, 11:51 AM
Hi Stan,
Looking at the 84 wiring diagrams (different than the 83), it looks like I can jump the L-jet (AFC) relay with a Y-jumper going terminal 30 to two terminal 87's. I may give that a try unless you see a problem.
Thanks,
Dave
Old 03-01-2020, 11:55 AM
Mrmerlin
Team Owner
Mrmerlin's Avatar
I would suggest to get a new relay and use it ,
many times a jumper has fried an otherwise perfectly working harness.
Given where the car is you should be using the part that will only work in one position
Old 03-01-2020, 12:26 PM
Thanks, Stan. I just ordered the relay. Either way, it won't hurt to have a spare, or it fixes my problem.
Dave
Old 03-01-2020, 01:20 PM
Mrmerlin
Team Owner
Mrmerlin's Avatar
Keep us posted Dave
Quick Reply: Ljet crank no start NO spark
