928 Forum 1978-1995
Sponsored by: 928 Specialists
Ljet crank no start NO spark
Old 04-09-2020 | 12:30 PM
  #76
j.kenzie@sbcglobal.net's Avatar
Yep. Three new relays coming tomorrow. Someone here said "relay, relay, relay" , so I ordered three.
Dave
Old 04-12-2020 | 01:04 PM
  #77
Just to give an update on this thread.
Car is starting great. In a 70 degree garage, cold first start of the day take less than a second of cranking.
I went through some issues with the ignition switch, and an add-on relay designed to send full 12 volts to the 0.4 ohm resistor leading to the coil(because my mini-starter does not do that). In cleaning up my wiring while waiting for the new ignition unit, I accidentally eliminated the ground leading to that add-on relay. When that was resolved, no more engine running on, and very quick start-ups. I believe I had a combination of small problems (plus mental error on my part) all contributing to the no start problem I began with.
Thanks for all the help,
Dave
Quick Reply: Ljet crank no start NO spark
