928 Forum 1978-1995
Sponsored by: 928 Specialists
Speaking of alternators
Old 03-05-2020 | 02:24 PM
  #31
928NOOBIE's Avatar
928NOOBIE
Originally Posted by dr bob
Forgive me from pointing this out. I'm sure it's a trick of the camera in your fourth picture, but...
That wiring harness and the wires showing look like they were last serviced by a wild Madagascar feces flinger. Those large brownish crispy tubes used to be bright red primary conductors. The patched-together wiring to the pressure sender and the oil level switch are I'm sure atypical. Broken heat and oil sleeve too. I'm sure the rest looks brand new, and this is just a local condition meant to fool us. [/rant mode]
As shared earlier, we place a whole lot of faith in a new alternator curing some very basic wiring deterioration issues in our cars. Upgraded higher-output alternators make more heat in those wires and connections that now have higher resistance.
In my casual opinion, you'll gain back the lost capacity plus get to use any extra the new alternator has if you can replace the front-of-engine harness with a new one. Several of our vendors offer modern replacements with tinned corrosion resistant marine conductors, modern more oil- and heat-resistant insulation and heat sleeves, and will put bigger primary conductors in the harness to support the extra alternator capacity. Get with Roger at 928SRUS, Greg Brown of the massive alternator upgrade fame, 928 International, etc. You'll be a LOT happier, and a slew of sniggly electrical gremlins will exit the building once you can get enough current through those wires to bring the voltage up.
The car will run better also; these things love voltage. When I put Greg's alternator in I experienced a noticeable improvement in engine smoothness and power delivery. Put a new ground strap on the battery and engine if you haven't already; they can look OK but are crap underneath....neither are expensive.
Old 03-05-2020 | 03:11 PM
  #32
928nut's Avatar
928nut
Originally Posted by Kongmiami
This looks like a great option. You can bet that these(if ford motorcraft part is used) have millions of miles of real world testing under its belt. Has anyone used on a 928 vs 944?
Could be but I am not looking for a new alternator. I have an alternator that gives me what I was looking for. The only problem I had was that the cooling cover didn't fit, as claimed by Eagle Auto Electric. I had 2 options - use it without it and see what happens or try to modify the cover to make it usable. Chose the 2nd option, done, worked out beyond my expectations, I am HAPPY !!!
Old 03-05-2020 | 03:35 PM
  #33
rjtw's Avatar
rjtw
+1 on an underlying problem that an unneeded aftermarket “upgrade” would only mask. Looks like you have an earlier car, so do I, an ‘83. I have always run the stock alternator and even with dual 100w halogens back when I ran them, a powerful amp, full AC and everything on the car running I have never had a lack of electrical power, surges, dropouts or charging problems. It’s been entirely reliable and uneventful, frankly. OTOH, my harnesses were never as bad as yours. In fact I was really on the fence about the need to replace my front-of-engine harness but did the research and found that people were reporting very positive stories after replacement. In retrospect, I think I caught things just prior to having them cause issues.
In any event, your car your money but you need to do the research too and understand the issues. Find your underlying problems (we’ve already pointed out the obvious ones) and you and your car will be MUCH happier in the long run.
Quick Reply: Speaking of alternators
