What is the correct tyre pressure for my tyres?
Hi!
I've got 255/40/17 tyres on the back and 205/50/17 on the front. I currently pump them to 2.3 bar.
What is the correct pressure?
As far as I know you should always inflate lower profile tyres more than standard tyres as there is less tyre between the road and the wheel so its more likely to get damaged.
The opposite should be true for wider tyres as the pressure per square cm is less as there is more rubber to carry the weight.
That said I would stick to at least the original pressures.
Johan
Johan
Range Master
Pepsie Lite
Pepsie Lite
36 and 44 baby.............works for me. As you can imagine, this is a much debated topic.
Are you talking about 16" rims or 17's? The 16's are 36/44 (works for me also), but for the GTS the rear 255/40 17" was dropped to 36 psi by Porsche, not 100% certain though......but know it was lower then 44.
928 Collector
44 is just not realistic with today's rubber. Agreed much debated, but when you realise that 44psi is ***many tyres' max permissible pressure*** you realise that you just cannot safely do that.
Personally I go for 34 all-round. On 17's and 16's. Johan, wheel damage isn't the point brutha :-)
The old Bridgestone RE71s (stock factory tire for the 928 GT) that I had on my previous '89 S4 5 speed were not good at 44 psi........funny as it was a factory tire. The middle of the tire would wear faster.......not that much, but some, and the ride/handling was not as good as when the pressure was set lower.
Now the Pilot Sports I have on the GT right now are perfectly fine with the 44 mark.......good ride and handling......and seem to wear much better straight across.
So some tires might be fine with it, while others may not.......
I have to agree our highways are gr8 especially since installing the lazar scrambler.
In town is a different story though especially in the rain season. They do fix the potholes but once through is enough to cause damage.
Johan
Johan
Johan
Johan
Nice to see more "Saffies" here. You guys gonna be at time trials / DK challenge this year? I'll be testing my 928 racer at Midvaal next weekend btw...
Pierre.
And South Africa invades Rennlist!
I think I'll make the rears 2.5 and the fronts 2.3 then...
I recently (about a month ago) had my tyres swapped around (inside wear) and also rebalanced the wheels. Trusting the tyre company, I did not check the tyre pressure until this weekend when I filled up my tank. Much to my dismay, I realized that the wheels were on different pressures (one of the rears at 1.8 bar!!! ).
In this month period, I have travelled to Lichtenburg (via the R28 over REALLY bumpy roads) and other not so good roads. I didn't really hit any potholes, so can my wheels be damaged? How can I make sure? I certainly don't hope so, as I've got Boxster S mags and they cost R21 000 at Porsche!
Thanks Old & New (Testament is it? )
I had them aligned two weeks before the swapping around, but the wear was from the misaligned period before then...
