928 Forum 1978-1995
Sponsored by: 928 Specialists
1985 Garnet red 5 speed, Barn Find, Lola 710
Old 04-24-2020, 10:07 PM
  #46
XS29L9B
XS29L9B's Avatar
Originally Posted by Mrmerlin
I went with the stock tire size
225-50/16
Jay . Make sure Your girlfriend knows she’s part of the project.
if she is not gonna support you it’s best to find another gal that will
Using this advice will save you both lots of heartache
BTDT
Note if a woman doesn’t like what her man does
She will never support him so he can realize his greatest good
A man will quickly get tired of this and find a new companion
Sometimes the machine is still here and the woman is long gone
#Truth
The following 2 users liked this post by XS29L9B:
drkekar (07-02-2021), Mrmerlin (03-04-2021)
Old 04-27-2020, 08:34 PM
  #47
Mrmerlin
Team Owner
Mrmerlin's Avatar
Received 2,388 Likes on 1,345 Posts
Got some more done, getting into the interior refresh,
start at the back and work to the front .
I like the lite color of these Sliverknit carpets the Sawgrass Coco Mats also will compliment this build.
Dash is coming out for a recover same for the A pillars
The following 2 users liked this post by Mrmerlin:
928NOOBIE (04-28-2020), pauliegirl (04-27-2020)
Old 04-28-2020, 09:31 AM
  #48
Chuck Schreiber
Chuck Schreiber's Avatar
Good Stuff Stan!!
She's going to have a GREAT car when she gets it back!
Hope she becomes part of the community when all is said and done.
Looking forward to your next "installment"....
The following 2 users liked this post by Chuck Schreiber:
Mrmerlin (03-04-2021), pauliegirl (04-28-2020)
Old 04-29-2020, 07:03 AM
  #49
grepin
grepin's Avatar
Yeah loving the posts. I am into all this stuff. All to do on mine yet. As you know intake refresh going on right now.
Old 04-29-2020, 07:25 PM
  #50
Mrmerlin
Team Owner
Mrmerlin's Avatar
Keeping on rolling got the A pillars and the dash out rear seats recovered.
Will be going with the black leather recover from Classsic 9.
Old 04-30-2020, 01:09 PM
  #51
pauliegirl
pauliegirl's Avatar
Chuck:
Maybe I will see you sometime in Texas; my daughter is in Melissa and grandson in Allen.
Old 05-01-2020, 04:24 PM
  #52
Chuck Schreiber
Originally Posted by pauliegirl
Chuck:
Sounds great! They are just right up the road!
Mrmerlin (03-04-2021), pauliegirl (05-01-2020)
Old 05-03-2020, 10:43 PM
  #53
Mrmerlin
Team Owner
Mrmerlin's Avatar
took the pod apart to swap in a new gear, note the missing teeth where the pinion gear is
this one broke when i reset it while driving around the block on initial test ride.
used some copper wire to shim the odo stack
Old 05-03-2020, 10:55 PM
  #54
JayPoorJay
JayPoorJay's Avatar
Thanks for,,,, everything! Really!
What does this mean (the copper), and why? Just need ta know...
Old 05-04-2020, 06:10 AM
  #55
Mrmerlin
Team Owner
Mrmerlin's Avatar
The wire acts as a shim
it holds the stack close to its drive gear
this so it won’t bind from sliding apart
i used wire from a phone wire it’s solid copper
Old 05-04-2020, 09:34 AM
  #56
JayPoorJay
JayPoorJay's Avatar
So that's the bottom resettable counter,,, LH side once installed?
Old 05-04-2020, 02:21 PM
  #57
Mrmerlin
Team Owner
Mrmerlin's Avatar
its the main cluster of odometer numbers ,
you will see this when you take one apart ,
the rack of numbers slides side to side if it moves enough then the drive gears will disengage.
The wire simply holds the rack close to its drive gear mating
in the picture you can see the shorter stack of the trip odo gears under the main odo rack
Old 05-04-2020, 03:28 PM
  #58
JayPoorJay
JayPoorJay's Avatar
in the picture you can the shorter stack of the trip odo gears under the main odo rack
Amazing. Got ya. I replaced my gear but didn't know this added preventative... Thanks for showing! I'll do it.
Also. Prepping to replace motor mounts with Volvo mounts from Roger on my 86 Manual... Thanks for the great write up with a pic showing PROPER engine height. It's my guide. Thanks for all you contribute here. Couldn't afford this car without you (and folks) sharing their invaluable experience!
Peace!
Old 05-04-2020, 09:24 PM
  #59
Mrmerlin
Team Owner
Mrmerlin's Avatar
NOTE on the Volvo MMs they now come supplied with the safety separation strap,
this means its easier to install them as you can leave off the lower finger plate,
the strap will prevent the mount from coming apart, plus leaving the plate off will make installing them a lot easier.
For the ODO issue
I figured this out by doing the job twice on a fresh Odometer gear swap,
it worked perfectly during the test ride after refitting then about a week later the customer said the odo had stopped working.
By accident I went and backed the car up for about 200 feet then went forward and the odo started working again . I guess that the gears had gotten jammed
So I took it for a drive on some twisty roads the odo would work then stop then work then stop.
at that point i went and checked the wires in the trunk and on the transaxle all seemed to be in order,
so out came the pod.
I took the speedo out and started looking at it carefully thats when i noticed the slightly more then a bit of side to side play of the odometer number rack.
So i took it all apart and thats when the fun began ,
as i was trying to remove the center rod to put a thin washer on the end to set the numbers closer to the gear drive,
a few of the number wheels fell out of place this made the whole set of numbers begin to have mismatches.
I should have taped the wheels together before removing the center rod.
Anyway it was a fun 2 hours till i got this speedo back together.
Now i know better,
take a piece of copper wire ( I got this from some discarded phone wire like you would find in an old house where you the 4 colors running through it),
remove the insulation,
make a U ,
slide it around the rod, pull the ends ,
then one twist and bend around the bronze collar it should last a lifetime.
Ghosteh (05-06-2020)
Old 05-05-2020, 10:33 PM
  #60
Wisconsin Joe
Wisconsin Joe's Avatar
Dwayne's write up on the odo gear covers the slop in the 'number stack' and the need for shims.
I didn't think I had enough slop to matter, and I spun the odo for a good while to test it out (Dwayne covers the testing too).
So, of course, about 4k miles later it stopped working. Went into it again, shimmed it with a thin washer and it's worked fine for the last 18k or so miles.
Quick Reply: 1985 Garnet red 5 speed, Barn Find, Lola 710
