Hello gentlemen. The seat switch on my passenger side 1987 model year seat just stopped working. More specifically, the back rest recline switch gave up the ghost and, of course, it’s stuck in an unusable position.
That adjustment switch worked briefly and then stopped working, that to me suggest the switch rather than the motor?
All of the other switches work.
It looks like someone else is been in there because when I pulled the cover that holds the switch panel on the seat in place there were missing screws, so my guess is this is not the first time there’s been a problem with it.
Any Hail Mary things to try or do I need to just suck it up and replace that switch? If I do replace the switch is it the switch panel that has both switches mounted?
If you can get to the connector for the recline function and add 12 volts to it, you can get the motor running...polarity determines the direction....
so so happens I have a set of s4 seats in front of me upside down working on seat electrics...
for 12V I’m using my battery charger set on manual..12 v...2amp...plenty to drive the motors. Then alligator clips to the jumper leads. I’d imagine the connector maybe tough to reach while the seat is in. Try raising as high as you can front and back.
This is a right of passage with a 928. One of my first jobs. Pull the switch and repair it or replace it. There are a number of DIY's on how to fix these switches. Also, make sure the plastic bits and gears in your rails that control forward and aft motion aren't about to crumble, since the seat is out, it's an easy inspection and maintenance item.
Thanks Ed - will give Tom/Mark a ring on the replacement switch.
Just set it at a usable angle and drive it. It’s the passenger side, and you’d need two switches to be able to adjust both ways.
Or I can just reverse the polarity of the connections as needed to adjust it, but per your suggestion it is going back in as I have bigger fish to fry.
