What is the correct battery for a 1986.5 928S?
I have a 1986.6 928 S. Trying to figure out, what is the correct battery size. 86.5 have the same size like a 87? Are the 86 and down different size?
Thanks in advance
Thanks in advance
Open up the box and measure it, paying particular attention to the depth. You want a 12 volt battery that is not so tall that the top posts will contact the metal lid when the lid is closed. Other than that get one that is as large as possible and still fits. Just my suggestion.
just_drive (11-13-2019)
Chronic Tool Dropper
The dual exhaust pipe cars use a Group 48/H6 battery.
As Jerry says, always fit the biggest battery that will fit, unless you are seriously into weight saving. The box is big enough for a DIN88 unit, so why would you go for anything smaller? Or did the box get smaller in later cars?
jp 83 Euro S AT 57k
jp 83 Euro S AT 57k
Box is shorter on dual pipe cars. Room is needed for the right side pipe to pass behind the differential and forward of the battery box.
I remember my '87 had a HUGE *** battery. What a bear. I forgot the frame size but looks like OP is all sorted out.
Indeed, installing dual exhaust on the '82 rally car i had to cut the batterie box a bit to clear that pipe and can only use a smaller batterie. ( same but shorter)
Inventor
From the '86 Service Bulletin (='86.5):
• Smaller battery housing due to new exhaust system. This also meant using a smaller size battery, approximately equal to a 66 Ah battery case. However, the battery capacity is 72 Ah. This was accomplished by a new plate design. Cold test current 420 Ah, weight 19.8 kg, low maintenance.
