On my '85 euro that line goes to a splitter near (and going to) the brake booster check valve (blue and black valve), the other sides of the splitter run through the fender to the CC servo and bubble tank thing
Thank you! That was helpful to compare. That’s what I have as you can see in the pictures below. One from the firewall, one two brake booster and the other to the Cc. As you can see in the pic I am holding that other vacuum line in my hand. It’s mounted on the firewall like it’s suppose to be there!
Firewall to splitter Black hose going into firewall Me holding mystery line
Black blue check valve going into booster
Are you missing an injector ground on the cam tower in that last image?. I forget how many there are and whether fore and aft on both sides..
