Adjustable 928 Fuel Pressure Regulators in stock.
Developer
Adjustable fuel pressure regulators allow you to get the most out of any investment you have made in power-adders for your Porsche. Anything that you have done to your 928 that has increased air flow through the motor like an exhaust mod, cat-delete, head, cam, or valve mods, or a supercharger - may have left some HP on the table unless you also added in a bit more fuel pressure too. While this is true for both LH-Jet cars and L-Jet cars, it is especially true for the L-Jet cars as they do not have the MAF nor the computer to increase injector on-time with increased air flow like the LH-equipped cars do.
Our adjustable fuel pressure regulators are a bolt-in swap for the stock Bosch Regulator. We have models in stock to replace Bosch 0 280 160 215 and Bosch 0 280 160 297.
The diaphragms are made with two 3-layer fluoroelastomers and designed for use with gasoline and ethanol and alcohol.
I have them priced below the stock regulators at $282.50 for the moment, and we have seven of them in stock. First come, first served!
Webpage: https://928motorsports.com/parts/fuelregulator.php
Interesting, Carl. How would you use them with your L-jet kit? Would they replace the RRFPR that comes with the kit? Are they responsive to boost?
Thanks,
Dave
Thanks,
Dave
Developer
I'm checking with the engineer who designed it about your question re: how it will respond to boost. I think I know the answer but I want to be sure. I'll get back to you.
Developer
Got my answer back: they said it was designed to work with turbo applications and yes, it will respond to boost at a 1:1 rising rate. The FMU that you currently have does allow you to adjust the rate at which the fuel pressure rises, while this one does not. But then again, this one bolts into the stock fuel system without any special plumbing.
Developer
Can these be used on an 86.5 and set at the correct pressure but then increased to the pressure on the '87 FPR when going to Porken chips ?
Bigger question: Can the 86.5 ones be set at the "factory" to the 87 value by default so I don't have to hook up a fuel pressure gauge? :-)
Inventor
Beautifully made. Any pictures installed?
Developer
The range is from 10 to 100 psi. I've been selling these for more than a year - I will ask those customers to send in some pictures of their installs.
The reason I posted is I know the 88-95 regulator has become hard to find for 928 owners, and I wanted to tell you guys I had these in stock. They are beautifully made, as you said.
slownrusty (11-13-2019)
Next question: Are they rebuildable?
Developer
Yes they are rebuild-able. I can even get replacement diaphragms when you need one, but as of yet, nobody has needed one.
We have fuel rail gauge kits in stock too. We use a smaller gauge now so it is an easier install on L-Jet cars, but it fits all LH-Jet cars too.
