Dont forget the rear top mounts only go up 1 way!
jp 83 Euro S AT 57k M474
..and the bottoms only go in one way..
..point being..
put the top in...then...
put a screw driver in the bottom mounting hole of the shock assembly and slowly rotate it to the correct orientation . because remember when it was assembled you probably didn’t counter hold the shock shaft at the top when you put the top nut on and tightened it anyway.
just don’t hit that top nut with an air wrench and let the shaft spin inside the shock.
The front shock mounts have symmetrical bolt patterns. The rears ARE NOT, in my experience of refitting Bilsteins. First rear went straight up, no problem, Second one, struggled for a long time before I realized they top bolt pattern was asymmetric. then it was quick. Just trying to save you time if you werent aware.
