928 Forum 1978-1995
Sponsored by: 928 Specialists
Stuck water bridge bolt
Old 10-12-2019, 09:01 AM
StratfordShark
StratfordShark's Avatar
Originally Posted by Mrmerlin
I suggest to clean the threads and use some PTFE pipe non setting sealant on the bolt threads this will keep liquid from entering and corroding the bolt back in the head
the same stuff can be used on water pump bolts
Thank you I'll get hold of the sealant. I'd like to clean the threads out but don't have M8 thread chaser. What's an alternative?
Old 10-12-2019, 09:12 AM
Kiln_Red
Kiln_Red's Avatar
Make it from a spare bolt that is the correct thread pitch.
Old 10-12-2019, 10:53 AM
StratfordShark
Thank you. I have the old water bridge bolts (less the one which snapped years ago)! I'm hopeless at metalwork so what's best way to cut the V-slot in the shaft?
Old 10-12-2019, 11:01 AM
Kiln_Red
Kiln_Red's Avatar
Easy peasy. Put the bolt in a vise. Do you have a Dremel or a die grinder? Just notch the bolt threads such that the indentation is tapered according to the photo. Wider at the top (first threads) to narrower as you cut toward the head.
You can also use a belt sander to accomplish this. That's what I have started doing.
Old 10-12-2019, 11:05 AM
StratfordShark
Fortunately I have the Dremel out now being used to polish various parts, so I'll have a go with the grinding accessories. Thanks a lot!
Old 10-12-2019, 11:08 AM
Kiln_Red
Kiln_Red's Avatar
Cool! Good luck with your efforts and may it be a productive Saturday.
Quick Reply: Stuck water bridge bolt
