Super charger install, fourth report.
#33
Range Master
Pepsie Lite
Pepsie Lite
are you guys talking about a bolt that holds the blower on the bracket? I mean what is the problem, that you hafta take the belly pan off to get to it....
In context of doing a TB/WP job (which was the reference "difficulty factor") I don't see this as a big deal. I am just happ Tim used a heathly 9/16 bolt for this application. I have had it with allen head cap bolts on this engine....
#34
Awww, I know it isn't thaaat bad. But as someone pointed out recently, I just need to bitch about something.
Needing to tighten the bolt one flat at a time is what bothered me about it, but you are old and patient, so I understand that would not be an issue for you.
#35
Hey Gretch, in reference to your pic showing the I/C to oil vent system line clearance, (where it looks like the hose is pinched between the I/C and the intake) why not just turn your Adel clamp upside down???? It "looks" like that would raise the line up high enough to prevent the pinch. (not critiquing, just trying to help)
#36
Range Master
Pepsie Lite
Pepsie Lite
Chris, it might work, I will try it.
Thanks.
#38
Range Master
Pepsie Lite
Pepsie Lite
Old, I know what you mean, I now own 3 count them THREE torque wrenches...................
Kit $8grand
Beer $coupla hunnert
bandaids $10.38
tools $ prox 300 buckeroonies
"Large furry ones" PA-RICCCCCE-LEEEESSSSSSSSSSSSS !!!!!!!!!
"Step aside boys"
Kit $8grand
bandaids $10.38
"Step aside boys"
