I am getting a new set of aftermarket wheels..........should I use the factory one or should I buy a new set from Porsche? Actually can I still buy those form Porsche? Any and All advise would be appreciated
I am not aware of a modern TMPS system that will plug-and-play with the TPMS display that is in ‘89+ clusters.
The TMPS system of the 928 - called RDK - relies on having two ~1 inch holes in each wheel barrel in which one-half of the “sensor” system in mounted. The rest of the system is mounted on each corner of the suspension. It is the automotive equivalent of a vacuum tube-based computer.
