While attempting to pull the oil pump out I noticed the shaft seems to have quite a bit of end play.
I measured the in-and-out movement at .0520". Is this normal?
Is the pulley loose?
I would remove the pump and inspect it and see if you can ID it via posted pictures also use the part number it has stamped on it
I know its just a casting # but the newer pumps have a different #
Most of the pumps that I have replaced are due to a shaft that has a bit too much wiggle of the shaft side to side,
this is due to running with an over tightened Timing belt, and or using an oil thats too thin.
That said on a car with only 32K miles I would not expect any issues with the oil pump, IOW its OK
The pulley was good and tight. I didn't notice the shaft movement until after the pulley was off and I attempted to remove the pump. The shaft has no play at all as far as side to side movement goes.
Oil pressure was normal. Probably not and issue as you said.
I'll check the end play again when I get the new o-ring on and re-assemble to see if it's the same.
