928 Forum 1978-1995
Sponsored by: 928 Specialists
Fuel lines
Old Jul 24, 2019 | 08:47 AM
Dylan_928's Avatar
Dylan_928
Default Fuel lines
I have a cracked hose and i cannot find a new one anywhere. Could someone tell me where i could find one? For an ‘89 S4
Old Jul 24, 2019 | 08:50 AM
buccicone's Avatar
buccicone
928sRus or Greg brown
Old Jul 24, 2019 | 09:23 AM
Dylan_928's Avatar
Dylan_928
Also would like to know what this hose is called.
Old Jul 24, 2019 | 09:50 AM
bureau13's Avatar
bureau13
I would think you would want to replace all the engine compartment fuel lines while you are at it. You can't always see the failure points on these things. When I got mine, the PO was doing some work on it prior to sending it, so I had some of Greg's fuel lines sent, even though they all looked good from a cursory examination. Sure enough, one of the old lines was compromised, we just didn't see it until it had been removed.
Old Jul 24, 2019 | 11:40 AM
beran earms's Avatar
beran earms
I just finished installing GB set of lines. Nice quality and worth it to me to not have my 928 turn into a raging inferno. I got my set from Roger at 928rus.
Old Jul 24, 2019 | 12:49 PM
Dylan_928's Avatar
Dylan_928
Is there a link to the product?
Old Jul 24, 2019 | 12:53 PM
dr bob's Avatar
dr bob
Chronic Tool Dropper
The photo appears to show fire extinguisher powder residue. Might be interesting to hear some of the car's history. Might also be interesting to do some more clean-up there especially if that is in fact dry powder extinguisher residue, as it's more than a bit corrosive to aluminum and electrical connections.
The hose you are pointing to is the fuel pressure regulator to fuel cooler hose. The fuel cooler is that cylinder clamped to the firewall, with AC connections on the end and the two fuel connections from the bottom. The other fuel connection runs to a steel return line that proceeds down the firewall then to the right side of the tub and back to the fuel tank. Both of these hoses should be replaced if they are original, as should all the other fuel hoses in the car. At 30+ years old and a life in a hot engine bay, they pose a serious risk of fire.
Many of the engine bay and rear fuel tank and pump hoses are still available as OEM or factory replacement pieces. Check with your/our favorite 928 parts vendors. Where original pieces are
no longer available, there are some very robust modern replacement pieces that will get the job done safely.
The hose you point to is readily available, as is its partner to the tank return line. Under that hose is a U-shaped section that's a bit more of a challenge, as it connects the rear of the fuel rails via the fuel pressure regulator and the rear damper. The original bend radius is too small for anything but a formed hose without risk of collapse, so the replacement from Greg Brown uses right-angle connectors and fittings. This is just one example of how the original design is improved with some modern products and thinking.
Contact 928 International in Anaheim, Roger at 928srus in the DFW area, Greg Brown at Precision Motorwerks in Orange California. Any of them will give you the parts guidance you need.
Old Jul 24, 2019 | 02:37 PM
worf928's Avatar
worf928
Plug this into google:
greg brown hose site:rennlist.com inurl:928
Old Jul 24, 2019 | 03:36 PM
Dylan_928's Avatar
Dylan_928
Day i bought
Old Jul 24, 2019 | 03:45 PM
Dylan_928's Avatar
Dylan_928
I bought the car the day after my graduation party for $2000 in St Cloud, Mn. The car was taken apart in preparation fir paint so i have been putting it back together piece by piece since june. The PO did a lot of body work on the car making the bumpers seamless and deleting trim and adding a different gas cap. The car was painted about a year ago and when they were taking it out of the booth the car started on fire but they put it out quickly and there was minimum damage. They werent able to paint the sunroof or spoiler because they decided to stop working on the car. I planned on wrapping them with carbon fiber. The car ran and idled rough when ingot it but after cleaning injectors and changing wires it ran much better! A few days ago i removed the intake and cleaned underneath that. I replaced both knock sensors and now i am working on fuel hoses so that it wont start on fire again. I plan on doing timing belt and water pump this fall/winter when the car is in storage.
Old Jul 24, 2019 | 04:08 PM
M. Requin's Avatar
M. Requin
A question and an observation: $2000 is a low price for a 928- what was wrong with it before the fire? And (donning flamesuit) I very much like the seamless bumper treatment. The dual exhaust not so much maybe, but some interesting ideas here. More history would be very interesting if you know it.
Old Jul 24, 2019 | 04:10 PM
Dylan_928's Avatar
Dylan_928
No issues as far as i know. The guy just didnt want to deal with the car any longer. It was completely take. Apart. Also there were no headlights, fog lights or tail lights when i got it. I only need foglights now. I have put almost $1500 or more into the car in parts already
Old Jul 24, 2019 | 04:25 PM
worf928's Avatar
worf928
Ummm.... I hate to be a dose of reality here.... but you are several thousand dollars in parts away from having that running well. Every single bit in that engine bay that is made of, or contains, rubber or plastic probably needs to be replaced. Every sensor. Every hose. Every rubber or plastic vacuum line. Injectors need to be sent out or replaced. All four harnesses (LH, front main, ABS, lights) need to be very carefully examined and 'ohm'd out' to rule out damage or just flat-out replaced. The front main and light harness carry unfused power direct from the battery. Damage to those harnesses can very easily start another fire.
What did it start out life as? I know it's 87+. But what year? Transaxle type? How many miles?
Old Jul 24, 2019 | 04:30 PM
Dylan_928's Avatar
Dylan_928
Like i said, the fire was contained and put out quickly. Damage was not a lot. The car runs and drives perfectly except for the small leak in one of the hoses. Only the temp sensor was damaged otherwise everything else is good. The injectors are perfectly functional and the picture is how they looked before i cleaned them and tested them. All i can say is i got a god *** deal.... the car is 89 S4, not sure of transaxle but it has 100,00
Old Jul 24, 2019 | 04:48 PM
worf928's Avatar
worf928
..., not sure of transaxle but it has 100,00
You don't know if it's a 5-speed or auto?
In any case: good luck. Seriously.
