Can't remove instrument pod
The allen bolts are slightly stripped....not totally but not quite there. Any solutions to break them loose? I need to remove to re-do my dash cover which was never put on correctly and to look at light bulbs etc.
When that happens to me I hammer in a slightly oversize allen wrench into the partially stripped socket. Of course that means you have the replace the bolt.
When I removed my pod I found those have something like locktite on the threads. You might try heating the bolt with something like a large soldering iron to see if it will loosen that way.
Mark
Mark
