928 s4 timing belt issues, motor locking up.
This is the one I use. Only $36 on Amazon. Helped me diagnose where my coolant was going (unfortunately into cylinder #1).
Rich
Rich
When you are looking down at the harmonic dampener bending over the front of the car, can you read the "0|T" mark just as it is shown in this post?
If no, your harmonic balancer is on backward.
If yes, and you have inspected the FULL belt path, get a borescope, and look in all cylinders for debris.
<edit: gear in N, handbrake on?>
Ref:
https://rennlist.com/forums/attachme...w-pics-132.jpg
Ref:
Have used a borescope and inspected each cylinder with no sign of FOD or damage to the top of the pistons.
Haha and yea car in neutral on jack stands. Have tried with the clutch in to eliminate anything further down the drive train being the cause.
Interestingly I did a test on all the hydraulic lifters to see if there was any slack between them and the cam lobe and found that I was unable to get a .002" feeler gauge in any of them . So if any valves have been bent it would be by such a small margin.
Will inform when the issue is found and what the finding happens to be . Thanks for your help either way.
