In tank fuel pump wiring
The wiring on my in tank fuel pump is not stock, so I don't have the different sized spade connectors to match the pump, let alone properly color coded wires.
The question is, on the in tank fuel pump, which spade is positive and which is negative? One is smaller than the other, but the pump body isn't labeled.
Archive Gatekeeper
The pump is labeled, at least in some years. Pics forthcoming, in a bit.
Thanks for clarifying that it should be marked. It wasn't obvious on mine, so I figured it wasn't marked. I found the below photo of someone else's pump online after your post. My hose and clamp are thicker and blocked view of the inset markings. But, with the below photo as a guide, I was able to spot them on mine too.
