Maxjax users
For those that might be interested in purchasing a MaxJax, I see that Home Depot has the older model on sale (the original non-ALI certified) for $1699 with free delivery to your door. According to a thread I saw at Garagejournal.com, some online vendors will price match and save you the state sales tax to boot. But I think I would rather deal with Home Depot and pay the state sales tax for the added security and put it on their interest free store card for 18 mos.
Um...
The Max-Jax lifts the car so the lift pads are four feet plus off the floor. Contrast with a full-height two post lift that adds two feet to that number. I'm not aware of any jack stands that will safely hold the car that high. If you are recommending normal 3T or even 6T stands instead of the Max-Jax, let me share with yiou that there is no comparison. I use jack stands for what they are good for. I use the Max-Jax for what it''s good for, which includes many of the things that jack stands are often used for.
Lifting a 928 onto four 6T stands is a several-step operation. As fun as that is, I'd much rather set the two columns, bolt them down and hook up the hydraullics to lift the car even if it's just to have the car up a foot or two. It's net easier, it's way safer and more stable than the car sitting just on stands. When I want to raise or lower the car to make accessing something a bit easier, it's a simple effort.
Jack stands are wonderful for people who haven't yet purchased a Max-Jax.
For my uses, I leave the posts bolted to the floor as I have the room to do so.
I drive the car in, and halt between the posts. I push the lifting pads into position. I push the "make the car go up" button. Done.
IIRC, dr bob has added a couple of additional pairs of holes at different heights for the lock bars, so he can hold the car at multiple levels without relying on the hydraulics.
This is a great idea, that I intend to steal.
UPDATE: Just saw your reply to dr bob. Makes more sense now. One question: where do you put the jack stands if you use the MaxJax on the jacking points?
I've actually only used the Max Jax for work on old muscle cars. I don't believe I ever did use it to lift a Porsche. I placed the jack stands somewhere else, like the subframe (unibody car). I think I've also placed them under the arms of the lift and snugged them up since they are threaded. I just used them for piece of mind to prevent the car from falling on me. Maybe unnecessary but the Max Jax is not a very heavy duty lift and my concrete floor in that building is of uncertain depth and strength.
Chronic Tool Dropper
I find that I'm a little lazy in my advancing years. Most work with car on the lift is done sitting down, on a "creeper seat" rolling chair that's about 12" high. For suspension and brake work, having the car up maybe a foot puts all the wheelwell stuff at perfect working height for sitting on that chair. For undercar work, the car goes up to full 4' height, where my bump-cap protected noggin is just below the height of the car's underpinnings as I roll around on the wheeled seat. As others mention, the lift arms are about the only hazard, hence the bump hat. At that full four-foot chassis height, wheels and tires are at perfect stand-up height for working if you feel that need.
Lighting while working under the car is a challenge I haven't yet perfected. I end up moving worklights around strategically when working under the car. Wheel well projects get a worklight inside, usually with padded magnets that grab the inner steel surfaces when needed. Others have come up with more creative solutions including extension-arm spotlights on short-legged reclining work chairs on wheels. These 'lighting problems' are the same ones you face with the car on stands or a lift.
