Hi guys
the ignition relay x
what does it control? Is it the while starter motor system. Spark etc? Or is it more specific?
i ask as I wonder if it was faulty, could it cause a crank but no spark condition?
cheers!
Ignition relay-X located in CE Panel slot IV is there to de-power the fog lights during cranking. This relay essentially has nothing to do with starting or running of the engine. it is called ignition Relay-X because it is controlled by the "X" terminal on the Ignition switch, and is not connected to the engine ignition in any way.
