Best way to find interior water leaks?
I can confirm that was the needed fix on the door! just need a millimeter adjustment and now closes really tight and no water from that side. Thank you!
Now working on the leak by the hatch lock mechanism on the hatch. When I removed the hatch lock itself, I saw that the gasket was torn. Good news is that i accidentally ordered one a long time ago and still had it. Now that is installed, but I am still getting the leak. water must be getting in the hatch itself somewhere and leaking out of the inside edge of the lock hatch plate that touches near the seal.
I just did another test and may have found the leak which is now pretty obvious.
When I tested running water done the middle of the trunk lid windshield, it was fine for a few seconds, and then water started shooting out of the inside center. I opened the lid and saw it coming out of the lock mechanism.
I then wondered how water was getting into the hatch body, and then I saw the wipers.
There is no cover gasket on the right wiper
Water must be getting in there and that is what is pouring out of the lock mechanism.
Sagres74 (04-28-2020)
