928 Forum 1978-1995
Sponsored by: 928 Specialists
Fuse relay wood panel question
Old Mar 9, 2019 | 04:06 PM
Betis's Avatar
Betis
Default Fuse relay wood panel question
I have a 1986.5 928S. Have a question on how the lower wood door panel is secured. In th panel by passengers fee, the lower door panel has 2 holes for 2 studs to go through. Are they wing nuts or nuts to secure them? On mine I only have the studs and that is it. Am i missing hardware to secure the lower panel?
Thanks in advance
Old Mar 9, 2019 | 04:08 PM
khalloudy's Avatar
khalloudy
It attaches to the top with two swivel ports and just push it to snug fit from the bottom.
Old Mar 9, 2019 | 04:11 PM
Betis's Avatar
Betis
So the 2 studs that go through the holes of the lower wood panel do not have any nuts to make it tight?
Old Mar 9, 2019 | 04:28 PM
Jason89s4's Avatar
Jason89s4
There should be a 10mm head nut and washer to attach bottom wood.
Old Mar 9, 2019 | 04:33 PM
Betis's Avatar
Betis
So I need 2 10mm nut to scew in the studs? Pictures?
Old Mar 9, 2019 | 04:59 PM
khalloudy's Avatar
khalloudy
Yes the lower portion is secured with bolts and washers if i recall
Old Mar 9, 2019 | 07:19 PM
polecat702's Avatar
polecat702
Vegas, Baby!
Veteran: Navy
Veteran: Marine Corps
The lower portion has a couple of washers and nuts in recessed holes. The top has a plastic hinge that is secured by a couple of wood screws and a single screw on each to secure it above the CE Panel, to a mount on the floor board.
Old Mar 9, 2019 | 08:49 PM
Betis's Avatar
Betis
Thank you so much all of you
Old Mar 10, 2019 | 03:15 AM
dr bob's Avatar
dr bob
Chronic Tool Dropper
When you go hardware shopping, the nuts are specified by thread size rather than wrench size. Shop for 6x1.0 (6mm) and you'll be a lot happier than with 10mm nuts. The oriinal nuts and washers are yellow cad plated if that makes any difference to you.
Old Mar 10, 2019 | 04:12 AM
Rob Edwards's Avatar
Rob Edwards
Archive Gatekeeper
Here's the hardware from an '89, minus the M6 washer that goes under the head of the acorn nut:
Old Mar 10, 2019 | 07:19 AM
Mrmerlin's Avatar
Mrmerlin
Team Owner
After you get your 6 mm nuts and washers
Make very sure that you have pushed the wire bundles away from each CE panel lower support .
Otherwise you can pinch wires and cause a short this can lead to letting the smoke out of your wires
OR damaging the O2 sensor wire harness
