What Is It?
What Is It?
Putting the dash back on I hit this little double bannana plug gizmo on the underside of the arm for the Ignition switch which kind of fell apart. I put it back together and it's a bit loose. I have no idea what it does as it seems to loop power or ground through the plug. There is no metal to metal contact with the arm.
I have attached a picture that shows it. I'll try to get something more close up tonight.
Regards,
JE
Regards,
JE
Re: What Is It?
Ooops. Here is the picture. The plug is circled.
Regards,
JE
Regards,
JE
I just got done putting all my stuff back together monday night... for the 2nd time
I cant make-out what that is circled in the pic... if you can get that closer shot posted, i'll try to help.
a black plug fits on there it should be directly under the 2 prong if you knocked it off. Theres only one plug that looks to fit it
Lou
04 scion xb
03 z71 tahoe
83 928 5speed
Lou
04 scion xb
03 z71 tahoe
83 928 5speed
Yes, but what does it do?
Lou
04 scion xb
03 z71 tahoe
83 928 5speed
Lou
04 scion xb
03 z71 tahoe
83 928 5speed
Perhaps if you stood waaaaay back when you took the picture our guesses would be more entertaining...
My guess - part of the flux capacitor power unit.
