Thinning the Parts Hoard
Adding to the list.
(2) Steering wheels with extended hubs - will need to be recovered. One is missing the turn signal cancel plastic appendage. $125
Kevin,
I will take 2 S4 Fans.
Harvey
Harvey
I'll take a crank and a ac pulley.
I'll also buy the radiator oil cooler if you still have it.
Also, how yellowed are your windshield washer reservoirs?
Adding again...
(1) Aluminum radiator from my 91 S4 - Thought to be from 928 Motorsports. $200
(1) Aluminum radiator - has Devek imprinted on it. Told it has a leak. $100 Own a piece of history. :-)
(1) Aluminum radiator from 89 S4 - identical to the on above no leak $200
(1) Behr radiator Side tanks don't have ATF or Oil Cooler connections $200
(2) red spares $125
(2) external ATF coolers $50
(2) red spares $125
Last edited by Kevin in Atlanta; 04-02-2019 at 03:35 PM. Reason: Adjusting quantities available
More parts....
(2) Pre S4 radiator viscous fans - tested $50
(2) Lower air box housings $25
(1) PS Upper timing belt cover - S3 $25
(1) DS Upper timing belt cover - S3 $25
(1) DS Upper timing belt cover 78-84 $10
More..
Partial set of intake for S3 $150
(2) S3 Throttle bodies $100
![](https://cimg7.ibsrv.net/gimg/rennlist.com-vbulletin/2000x971/20190330_131248_5a6052e6755eabb052fdedb5e74a1a1e49890d87.jpg)
