928 Forum 1978-1995
Sponsored by: 928 Specialists
cam timing fun (pics added)
Old 01-18-2019, 11:38 PM
Bigfoot928
Bigfoot928's Avatar
Default non factory cam timing fun (pics added)
Old 01-19-2019, 12:26 AM
GregBBRD
Basic Site Sponsor
GregBBRD's Avatar
Received 2,458 Likes on 1,460 Posts
Originally Posted by 928sg
Getting the Simard cams installed, and figuring out the cam timing. They don't have the little nubs on the cams that you line up with the chain links to get the intake and exhaust cams timed properly. I'm glad that when Mike was designing them I talked him into include wrench boses on them so you could turn them and get them dialed in. getting out the dial indicator. no pun intended.
The lobe location will not be that far different than stock. You can set them next to a stock set of cams and mark the basic timing marks for the chain.
Old 01-19-2019, 12:33 AM
Bigfoot928
Bigfoot928's Avatar
Old 01-19-2019, 01:09 AM
GregBBRD
Basic Site Sponsor
GregBBRD's Avatar
Greg, I will give that a shot from pictures. I haven't had my hands on a stock set of cams in about 15 years, so I'm a little rusty. I do have one of the knock off's of the factory cam silhouette so I will give that a shot tomorrow.
​​​​​​The factory cam silhouette should get you close.
I can get you some references of the chain location marks to the lobes, if you need that.
Taking the cams in and out to get the chains on the right tooth just isn't that much fun.
Old 01-19-2019, 01:13 AM
Bigfoot928
Bigfoot928's Avatar
Old 01-19-2019, 11:06 AM
SeanR
SeanR's Avatar
Sterling, swing over and borrow my cam lobe tools. Just return them when you're done. That will get you close enough.
Old 01-19-2019, 11:11 AM
Bigfoot928
Bigfoot928's Avatar
Old 01-19-2019, 05:01 PM
GregBBRD
Basic Site Sponsor
GregBBRD's Avatar
You should try it the 968 chain tensioner, and 2 of them was a royal pain. It's enough to make the Pope drop F Bombs. I used a time card at one point to see how much time I spent on cam timing when we were doing the 968 variocam on the 928. I had over 130 hours on cam timing alone.
Just setting the cam timing on a stock 968 is enough to make one crazy....I can't imagine what it must have been like in a 928 application, with two of those things.
The problem with the Porsche Factory 968 method of setting the cam timing is that it only works when the tensioners are almost brand new. Once the tensioners wear, there is too much leakage past the piston to be able to control the tensioner position...the cam timing becomes a continually changing thing. About 75% of the 968s I've seen that have had anyone mess with the cam timing are incorrectly set.
greg brown
714 879 9072
GregBBRD@aol.com
Semi-retired, as of Feb 1, 2023.
The days of free technical advice are over.
Free consultations will no longer be available.
Will still be in the shop, isolated and exclusively working on project cars, developmental work and products, engines and transmissions.
Have fun with your 928's people!
Old 01-19-2019, 05:22 PM
Bigfoot928
Bigfoot928's Avatar
Old 01-19-2019, 10:11 PM
GregBBRD
Basic Site Sponsor
GregBBRD's Avatar
This should get you close:
BTW, I have no idea why some of the pictures copied 90 degree off....
Old 01-20-2019, 11:26 AM
Bigfoot928
Bigfoot928's Avatar
Old 01-20-2019, 12:03 PM
SwayBar
SwayBar's Avatar
Sterling, that 928 MS cam-tool is definitely a top-ten tool for me.
Looks like it's working perfect for you, too.
Old 01-20-2019, 12:33 PM
GregBBRD
Basic Site Sponsor
GregBBRD's Avatar
this is what I have so far:
Step one done.
Old 01-26-2019, 06:47 PM
Bigfoot928
Bigfoot928's Avatar
Old 01-26-2019, 09:43 PM
IcemanG17
IcemanG17's Avatar
I understand how long term projects become messy..... I’m sure someone in your local area has one you could borrow, but the best answer is call Anderson.
Quick Reply: cam timing fun (pics added)
