M061 Headlight dimmer
Hi there,
Attached jpg is part of the ’89 schematics. In column H one can see a module named “(M061) Headlight dimmer”. What is that module actually doing? M061 is option code for UK cars. So when not a UK car, how are the pins bridged together? Or are they all five just “open”, connected to nothing. Wiring goes to a 5 pin socket but noting is plugged in that socket, is that it? Thanks for your inputs! Regards https://cimg7.ibsrv.net/gimg/rennlis...99e299ba43.jpg |
IIRC the UK cars had a "required" dim/dip feature. Headlights up but a smaller bulb used for low light situations. Need to go look at my 88 UK car.
Thanks Roger!
May I add a second question? Where is relay XXII “Backup lights” powered from in automatic cars? When I follow terminal 86 of this relay I end up at the instrument cluster connector 1 pin 4. Is that pin really powering relay XXII… … … Current flow diagram used 97-311 & 97-317, ’89 car. |
