928 Forum 1978-1995
Sponsored by: 928 Specialists
Manual Trans Mounts: Using 78 mounts in a later car
Old 01-07-2019, 06:04 PM
Hold On
Hold On's Avatar
Default Manual Trans Mounts: Using 78 mounts in a later car
Throwing this out for comments.
I have a 83 S with a 79 manual trans setup. Its time for fresh transmission mounts. The 79 up mounts 928-375-045-16 are god awful expensive, over $200. each. The 78 mounts are two different widths but a fraction of the cost, under $100. each. The reason they are different widths is because the 78 have a different battery box setup. I have heard that the 78 mounts can be used in the 79 setup as long as I use the two wider width mounts ( 928-375-045- 13) on both sides.
Has anyone ever confirmed this ? I did some searching but did not come up with a conclusion.
Thanks.
Old 01-07-2019, 07:16 PM
Mrmerlin
Team Owner
Mrmerlin's Avatar
Received 2,257 Likes on 1,250 Posts
Ok your on.
Please post pictures of the mounts you have,
and where they have to fit,
and order a set of what you think you need.
Maybe your going to teach everyone something here about trans mounts.
Old 01-07-2019, 08:53 PM
Hold On
Hold On's Avatar
I havn`t pulled anything apart yet. I was hoping someone may have done this mount swap before. Before I purchase parts. The manual trans and cross member are stock 1979 parts. Those mounts are #928-375-045-16. Both sides are the same because the battery box mount was changed in 1979. The 78 has two different widths of the same mount. I will keep searching here. I swear I saw someone who did this mount swap.
Old 01-07-2019, 10:22 PM
Mrmerlin
Team Owner
Mrmerlin's Avatar
Please post some pictures , talk is cheap, LOL
Old 01-07-2019, 10:42 PM
Hold On
Hold On's Avatar
Pictures of what ?? If I cant confirm it`s been done, I will order the one`s needed...
Old 01-08-2019, 09:46 AM
hacker-pschorr
Administrator - "Tyson"
hacker-pschorr's Avatar
Received 2,072 Likes on 1,183 Posts
I changed the thread title to better reflect what you are asking. If my 78 wasn't mothballed I'd climb under there and take some measurements compared to my 79 (which is already on the lift).
I sent a message to Mark Anderson, if anyone has a set of each lying around, he might. See what we can figure out with this idea.
Seriously Stan?
Old 01-08-2019, 10:08 AM
Mrmerlin
Team Owner
Mrmerlin's Avatar
Eric thats why I added the LOL.
This is an obscure request and without any pictures to go on it could turn into a cluster
I want to assist the OP but I dont recall the differences he is looking for ,
and adding pictures of the mounting area he has and the mounts will assist in a more accurate answer
Off the top of my head I dont know anyone that could answer this question from memory
Though Mark Anderson is a good idea where to start
For the OP look in the WSM as it details the changes that were made to the rear crossmember and trans mounts as the model progressed
This might include mounting designs.
Old 01-09-2019, 10:40 AM
Guy
Guy's Avatar
I installed the wider 78 mount on both sides of my 79.
https://rennlist.com/forums/928-foru...h-shudder.html
worked great!
Old 01-09-2019, 11:08 AM
Hold On
Hold On's Avatar
worked great!
Thanks for chiming in Guy. That was the post I remember seeing a while back. Now that you have some miles on the mounts, what`s your current opinion on the swap? They are certainly hefty mounts.
Old 01-14-2019, 10:09 AM
z driver 88t
z driver 88t's Avatar
This is a great thread. I am in the market for new mounts and was lamenting that it was going to be $400 for a set. Damn, those are some BIG transmission mounts.
Old 01-14-2019, 10:16 AM
Guy
Guy's Avatar
I would do it again in a heartbeat my shifts are solid and firm and the car is smooth as silk.
Old 01-14-2019, 11:38 AM
ROG100
Basic Sponsor
ROG100's Avatar
Unless you have bought the 928 375 045 13 already they are currently not available and maybe NLA.
Old 01-14-2019, 01:10 PM
Mark Anderson
The Parts Whisperer
Mark Anderson's Avatar
We have 1 left
Old 01-14-2019, 01:20 PM
ROG100
Basic Sponsor
ROG100's Avatar
Cue the Meme - $1000000 dollars.
Old 01-14-2019, 01:27 PM
Rob Edwards
Archive Gatekeeper
Rob Edwards's Avatar
Received 2,557 Likes on 1,236 Posts
Quick Reply: Manual Trans Mounts: Using 78 mounts in a later car
