MAS stuck
Cannot get My mass airflow sensor off of it and take it say 87 928 Asfoor I’ve got the 7 mm loose done done but I just stuck on the on the robber in take that’s above the throttlebody anysuggestions
^^^^there is no secret potion for this one, and it can be a PITA to remove. don't know if you can hit it with penetrant, or
maybe that is a bad idea? I had the same problem and followed speedtoys recommendation. finally got it out
on reassembly, i put a very light coat of Alladin Magic Lube which is a PTFE based lubricant used for swimming pool O rings.
good for wet and dry applications for temps from -10 to 425'
