Knock solution; seems too simple? Gasoline questions
#61
Without beating a dead horse, gas is obviously different at different stations. The OPs car ran better immediately on a tank of Shell. Seems like a theory worth pursuing.I can buy gas for my DD at certain stations and it will audibly detonate: not so at others.
what I could do, is run this tank down, and put it some Sunoco 100 octane race fuel. does the group think this would be a good test??
#62
Because we know..the fuel comes from the same terminal tap, with changes in detergents, not energy or octane capacity, added after the fact.
The Scientific Theory -is- useful, but only if you follow it. Nearly blind observations of a result, does not lead to any conclusions.
Buy some PEMs, borrow a ST, do science.
#63
Because you're changing conditions...obviously 100 will knock less than 93, but you already have a 0 result, another 0 result with different parameters is a waste of money and time.
Chase this down with a solid set of data points, and a tight methodology.
#64
I think the best test is to stick to one station, find out when they get deliveries and record that in a notebook, and then repeat the same test-drive every time you refill and note the ambient temperature, barometric pressure, humidity and knock-count and record that also. The Sunoco race gas would be boring because it won't knock at all. But if you had a Sharktuner then it would be fun to see how much timing you could add and how much more power you could make at the local dyno. Slippery slope, this is.
#65
above points well taken;
Speedtoys, only reason I am not pulling the trigger on ST, is that I want to install X pipe first, and with this and other projects on the table,
that won't (can't) be until after the new year. also, X pipe gives me the second bung for the wide band
for the moment, a friend with tools (FWT) is going to help with vacuum, fuel pressure, and smoke, tomorrow. I have the correct specs
for fuel pressure, (thanks fred) for not running and idle. is there a test for fuel pressure under load? at certain RPMs? useful or irrelevant?
any other specifics regarding vacuum tests: should I test each dampener separately, as well as the FPR? other vacuum tricks?
#67
... I have the correct specs for fuel pressure, (thanks fred) for not running and idle. is there a test for fuel pressure under load? at certain RPMs? useful or irrelevant?
The check for the two dampers is that they are not leaking fuel out the vacuum port. Disconnect the vacuum line and sniff, or disconnect the vacuum hose and route a small hose from damper's vacuum port to a catch-can and jumper the pump (with engine stopped).
This is from the '90-95 Tech Spec booklet, don't try to work on these cars without one:
#68
^^^^^^^thank you jim very useful information. will report upon completion.
a little more "testing" this AM: first step was to check my idle contact, and WOTS. idle fine, WOTS not working (not closing, stays open).
outside temps 65F. started the same way, lightly pushing down on pedal @3000, 4000, and 5000, and all readings were 0.
then I gave it the full monty, and got 18. pulled over and again checked WOTS and it was not working. stomped on the pedal and got
WOTS to work, another full bore run, and 18??
of course I cannot be CERTAIN, but I made many runs, and it "appears" that it makes no difference whether the WOTS is working or not.
does that provide any additional clues?
then, being Halloween, I journeyed to that special Shell station, and juiced her up. (ran fuel level down as far as I could) even went to the same
pump, #7.
performed all of the mentioned tests, and nearly identical results.....so no magic syrup at that store.
questions of the day, are nearly the same as before:
-what might have occurred to get those ZERO knock results?
-why am I not getting any different readings with WOTS working or not?
-and, hypothetical, WHAT IF, I put in super 100 octane fuel, and got the same results?
pump, #7.
#70
Have you done that intake refresh, that everyone has been telling you that needs to be done, yet?
and a lot more....
really appreciate all the insight provided thus far. hoping you might have an idea of where to go next??? gimme a new direction.....
#72
Only thing I have is to install a wide band O2 sensor and see what the air fuel ratio really is. Running lean will tend to cause knock. Maybe you have a "weak" injector.
in spec. unless, one injector is not firing, but I took a stethoscope to each one, and they are clicking properly. not sure what else might create a lean condition??
#73
X-Pipe O2 bungs only read one bank of 4 cylinders. At least that's how mine is.
Maybe go to a Dyno shop, which should have the wide band O2 wand they stick up the exhaust so it reads all 8 cylinders.
#75
Your only investment will be PEMs.
It was brought up earlier..have you done a full intake system refresh?
