928 Forum 1978-1995
Sponsored by: 928 Specialists
Oil Pin too large
Old 10-29-2018 | 10:56 AM
Adamant1971's Avatar
Adamant1971
Originally Posted by worf928
I would respond to this on the subject of talents 928 wrenches are reputed to have, but it wouldn't be work safe...
LOL
Old 10-29-2018 | 02:17 PM
worf928's Avatar
worf928
I’ve worked on several flip-up wing ‘87s all with ribbed-and-fuel-rail-spacer-needing intakes.
I’m not sure I’ve ever worked on a smooth intake.
Old 10-29-2018 | 02:19 PM
Speedtoys's Avatar
Speedtoys
Originally Posted by SeanR
788 VIN early 87. Took it off the car last week, even had the longer studs for the early fuel rails with spacers.
I'm #356 for 87
Old 10-31-2018 | 11:16 AM
firemn131's Avatar
firemn131
I am 344
Old 10-31-2018 | 11:26 AM
Kevin in Atlanta's Avatar
Kevin in Atlanta
This particular set of heads were on #439 parts car I bought in '13.
Old 10-31-2018 | 01:41 PM
jetson8859's Avatar
jetson8859
My 87 is #2255 and has ribbed fins on intake. This is the car referenced in post #4 which had the f'd up pins installed. New pins did drop right in. Not sure ribbed or non-ribbed intake is a good indicator of smaller holes.
Old 11-01-2018 | 06:39 AM
Hilton's Avatar
Hilton
Looks like you used some jbweld to fix them in too? They don't need it - they're held in place by the cam caps.
Originally Posted by Kevin in Atlanta
Sometimes I amaze myself.
Scored a drill press at a local estate sale and now have an opportunity to use it. That and a file made short work of it.
Finished product.
Old 11-01-2018 | 08:38 AM
baystate928's Avatar
baystate928
Dave,
Check your pictures. No ribs on mine.
Old 11-01-2018 | 09:52 AM
Kevin in Atlanta
No, that is HondaBond.
I use JBweld for projects like this:
JBWeld to secure the slip fit on the hot water connection to the heater valve
Old 11-01-2018 | 11:35 AM
worf928's Avatar
worf928
Originally Posted by baystate928
Dave,
Arg!,LOL. I distinctly remember checking your S4’s pictures and seeing ribs on the intake. Clearly those red 928s are mixing-up my picture folders when I’m not looking.
Obviously, I either got a joker in your deck or I was looking in the wrong place.
I stand corrected.
Quick Reply: Oil Pin too large
