Spark Plug Wires
Per Jim Bailey, Porsche built the resistance into the plug connector not the wires. So if you use non-OEM wires with OEM plug connectors, you will have too much resistance.
The OEM wires are higher quality and last 2 - 3 times longer than normal wires. So if you plan to keep your 928 use OEM wires.
