2 inch spacer too much?
I recently came across a set of 2" spacers, and was wondering if they would be too wide to use on the rear of my 79. Stock 16x7 phone dials, 225/50's. I tried to measure the rear of my car but could'nt come up with a solid answer.
Any comments? (pics of same if ya got em!)
Brian
Brian
I have 21mm spacers on my original 7x16 wheels. They fit nice and tight. I am not sure if you can get away with another 4-5mm or not, that is if our cars are dimensionally comparable. Some slight bending of the wheel arch might do the trick though!
I have seen some 928S without spacers and they look stupid in my opinion. I guess all had them when new?
I would suspect 2" spacers would be too much. Of course it depends on the wheel offset and tire size you use.
I have about 1 3/4" of spacers on the back of my '80 S, but it is a bit different from stock.
http://www.928racing.net/StanShaw.htm
Your 7X16's probably have an offset (ET) of 65mm. A 50mm (2") spacer will never fit a stock car - 25mm is more likely. Get an ~ 26" piece of wood at whatever width, say 1", and lay it across the face or the rear tire as installed: you'll quickly determine potential rub spots, etc.
