Refinishing vinyl parts interior
Hello all. Have an 86.5 S with brown interior-in very good shape except some of the vinyl parts have fading and scratches while the leather looks good with reasonable patina. Has anyone had a good experience refinishing those parts with a brush or spray on finish? Thanks
Originally Posted by Speedtoys
The refinish, will be more matte than original, and a little 'rougher' surface as well.
I also discovered that once the pieces were installed in the car, the sprayed pieces will stick to the adjacent/touching pieces. For example, my sprayed visors stick to the headliner and my sunroof panel also sticks. Map pocket covers also stick to the door panel. Not ideal.
Next time I'll forgo re-dying pieces and recover with new material or just replace with better pieces.
What about paint/dye material choices? I’d bet there are better products than typical aerosol vinyl dye. A lot of the interior parts don’t “flex” like a seat or or a foam backed quarter panel. A vinyl console, dashboard, glovebox, etc are very rigid and may dye fine with the right HVLP product. They make flex agents for bumper covers, a full spectrum of gloss to flat can be dialed in. Anyone gone down this road?
I had a 13k 79 Trans Am with a red interior. Even with low miles and stored inside, the interior plastics changed to an odd shade of purple. A light coat of dye really bought it back without giving it a dyed look. There is definitely a place for these products when used properly.
wrap them with a new vinyl. there's a bit of a learning curve but the end result is far more visually appealing (my opinion) than vinyl paint/dye. the faux leathers (modern vinyl) have superior uv resistance vs. vinyls from a few decades ago. there's a good variety of textures/colors/finishes. do the job right and your car is good for the rest of our existence.
experience talking here....if you're going to spray SEM vinyl/leather/plastic color, go very easy, multiple coats as light as possible with plenty of drying time. if you spray a heavy coat, the result will be far more glossy vs. matte
also, you can get a custom 2 part urethane mix from your auto paint supply store that's going to give a better result than SEM. have the shop match the color you like, have them add flattening agent, and if it's going on a flexible part, a flex agent. this is more expensive, and requires that you spray from a paint sprayer instead of a rattle can, but if prepped properly, will give a result that looks better and is more durable than rattle can products. its critical to remove any trace of old armor all, pledge, etc. from the surface to be painted, and you might end up needing an adhesion promoter
