Work Begins On The 79
Good work Scott.
I must check it out one day since I am in Adelaide.
I pulled my fuel tank out today.
I dont suppose you have a spare fuel sender.
Greg
84S Auto
Greg
84S Auto
Sorry Greg don't have a spare but I have one from the 79 you can borrow for a while if you'd like.When I have the new radiator in the 86 man you'll have to come and take it for a run. Old girl's got some mumbo.....thanks Ken
Much easier to keep clean. The front diff cover is at the polishers and all the nuts, bolts and studs are getting yellow zinced as well. Hopefully it will look good.
Guys, need some help getting those a$$hole torque tube bolts undone at the front. Is there a trick to getting those fuggers out? What a stupid idea to put them in there. I'm thinking I might get someone to fix studs in the bellhousing to make it easier next time.
How often do you figure you're going to need to pull the bell housing?
