Fact or fiction...OXS Signal wire
All -
Is the OXS signal wire (green wire - not the heating element) on my '83S shielded or not? When I disconnect the connector beside the CE panel, it appears on inspection that it is a 1-conductor wire [with no shielding] soldered to the pin in the middle. Would make sense as it is 3-wires in all to the sensor, so no terminal for the shield to attach to.
Thanks -
-scott
Thanks -
-scott
Chronic Tool Dropper
The shield probably connects to the shell rather than via the connector, unless it happens to share with the earth side of the heating element. Ideally, low-level analog signal shields are grounded at the source (sensor) end, and stay open the rest of the way to avoid ground loops and associated noise.
