Installing threaded fuel tank insert
All,
while installing fuel strainer the threaded insert spun. I purchased the insert from Roger and am attempting to install it. The issue I am running into is that the new threaded insert is up against the wall of the yellow plastic sump in bottom of tank but doesnt extend far enough into the outlet neck to allow the strainer to thread into the insert.
Plastic sump in bottom of tank
Here is picture of the gap between the yellow sump and wall of actual fuel tank. The gap is about 9-10mm
Pic showing outlet neck and the inner yellow sump. Again, gap is about 9-10mm
Here is pic of the threaded insert in the tank, its thru the hole in the yellow sump but barely enters the outlet neck.
it would seem that the threaded insert should be against the sidewall of the tank vs the inside of the yellow sump piece at bottom of tank so that the gasket on threaded insert and gasket on strainer would seal against each other.
I'm sure I'm missing something, any help appreciated.
Looks like someone took a hole saw to that inner portion of the tank. It should not be like that. I’m guessing that the piece in there rotated and someone put it in wrong.
But, more to the point are there instructions with pictures?
You have to pull it further through.
How are you pulling it into place?
Also, how are you ensuring the "finger" isnt resting in the wrong position? If it's facing downward, it wont seat properly or deep enough
I put a toggle bolt thru center and used that to pull both sides in evenly. The finger was down and pointed at the 4 o'clock position. It was my understanding that would keep it from spinning while threading the strainer in. I will adjust finger to 12 o'clock and see if that makes a difference.
Thanks, will make sure finger is pointed up and give it another go in the morning. Pretty sure it wont come thru as it wont get past the inner part of the tank. As shown in my photo above there is a double wall due to the brown sump that sender sits in.
Appreciate the help. It seemed pretty simple, didn't think about rotating finger up and let it turn when threading the strainer into the fitting.
Today we replaced the insert with the gas tank installed. After a couple of failed attempts we used the following rube Goldberg device to pull the threaded collar into position. The bolt and huge washer are inserted from inside the tank, the additional washers and rear lower suspension bit takes up the un-threaded portion of the partial bolt. Another victory for shade-tree and hillbilly mechanicing.
I've only ever installed them with the tank still mounted in the car. The next time I install one, I'll make a video.
It literally takes me 10 minutes to install one now.
I assume it worked out well for you?
I am glad that worked for you and look forward to the video. But, there was no way the insert would simply pull into position. Ask Kevin.
For us the insert stopped at the inner bowl with the tool at 12 o'clock. It simply could not be cajoled into position.
Once you got it seated and in place, everything worked out?
