928 Forum 1978-1995
Sponsored by: 928 Specialists
Shift rod bracket bushing replacement
Old Aug 9, 2018 | 06:43 PM
Majestic Moose's Avatar
Majestic Moose
Default Shift rod bracket bushing replacement
For the degenerate 5 speed folks, this is the bracket mounted to the torque tube just forward of the shift lever that locates the rear of the front shift rod. I doubt any of that makes sense so here are photos.
I only have a sample size of two, an '83 and '89, but the plastic bushings were totally disintegrated. I think it is fair to say by now they are all destroyed or will be soon.
These were the remnants I found in the foam.
This is what a new "bearing bracket" 928 424 017 05 looks like. (I found these photos on Sharkskin's site).
The whole bracket is available for about $125 but that is a bit much when all is needed is a piece of plastic. The rubber portion is still intact and pliable. I thought I would put this up to the brain trust to see if there were alternatives or if this might be a candidate for 3D printing?
Old Aug 9, 2018 | 06:49 PM
DR's Avatar
DR
Rennlist Sponsor
I have heard a few times of people sleeving that with just the right size PVC Piping split in half, IIRC
Cheers,
Dave
David Roberts
2010 Jaguar XKR Coupe - 510HP Stock - Liquid Silver Metallic
928 Owners Club Co-Founder
Rennlist 928 Forum Main Sponsor
www.928gt.com
928 Specialists on Facebook - 928Specialists
Sharks in the Mountains on Facebook - 928SITM
Old Aug 9, 2018 | 07:15 PM
Majestic Moose
Brilliant thinking! This set my gears in motion.
A 1/2" pvc coupling makes an almost perfect replacement. The OD makes for a tight fit in the rubber and I filed down a ridge in the middle of the coupling where two pvc pipes would meet. The shift rod has a little play inside so I will take another coupling and only file it a little bit so it is perfect. I am thinking I can cut a small groove to secure a zip tie on each side to keep it in place but it is not going to move as is.
Old Aug 10, 2018 | 08:06 AM
jwillman's Avatar
jwillman
My early car does not have this bearing bracket assembly. Not sure when it was added.
Old Aug 10, 2018 | 11:12 AM
Majestic Moose
It looks like prior to 1981 there was some sort of bearing attached to the body.
This is from the 1981 Service Info manual.
Old Feb 13, 2020 | 05:57 PM
islaTurbine's Avatar
islaTurbine
Brilliant work and thank you for the pics. The rubber portion was present on my bushing mount, but I didn't realize that I was missing this plastic bushing. I used 3/4" PVC pipe (the higher quality, thicker style vs. the cheaper 3/4" PVC that has thinner tubing). It's a perfect fit.
Old Feb 13, 2020 | 05:59 PM
islaTurbine
Old Feb 13, 2020 | 10:22 PM
Majestic Moose
Well done and I can report that this fix has worked well so far.
Old Apr 9, 2023 | 06:08 AM
928@AMG's Avatar
928@AMG
i am also thinking of a replacement for this sleeve.
Unfortunately, tube dimensions in inches are unknown in Europe.
Can someone please tell me the exact outer diameter of that shift rod ?
I have from someone the information that it is 20.3 to 20.4mm , is this true ?
Thanks in advance
Old Apr 9, 2023 | 02:56 PM
Darklands's Avatar
Darklands
Water tubes are often in Germany also in inch .
Old Apr 9, 2023 | 05:54 PM
Rob Edwards's Avatar
Rob Edwards
Archive Gatekeeper
The metal rod is 20.4 mm, and flares a little to 20.5 near where the flat for counterholding is. The ID of the rubber support in the shifter bearing bracket is 23.5 mm. So you need a 1.5 mm thick plastic ring with an ID of 20.5 mm, or 13/16" ID x 59/64" OD if you're sourcing stuff at Home Depot.
