Oxygen sensor appearance?
replacing my (original?) 87k oxygen sensor
of note: was loose and did not require wrench to take off??
does it look bad? or appearance does not reveal anything?
never seize on install?
Archive Gatekeeper
Throw that one away and install the new one (Bosch 13048), they usually come with antiseize on the threads.
why would it be loose? can that create a leak that would send bad info to the computers?
can an O2 sensor be "read" like a spark plug?
Archive Gatekeeper
Who did you buy your '90 GT from? You might want to consider putting a torque wrench on all your suspension bolts.... It was loose because someone didn't tighten it properly. Not sure what 03048 is, it doesn't come up in any Bosch cross-reference guide.
Rob: complete bosch number is 0 258 003 048
here is a link for that part
https://automotivesuperstore.com.au/bosch-0-258-003-048
will check other torques settings; still wondering if that could cause some sort in air leak, resulting in bad info to ECU
Archive Gatekeeper
If it was finger tight but not falling out, the air leak through the threads would be infinitesimal compared to the airflow through the cats. I doubt it affects any readings.
Team Owner
I did a google search for Bosch 13048
Looks like E bay has them for 76.00
https://www.google.com/url?sa=t&rct=...pQf_dSqgf_sEVv
