85 928 hunting idle and engine stalls
poor idle engine stalls when throttle is depressed. car sat for 10+ years, i have replaced caps, rotors, wires and plugs. i also drained fuel tank and put in new fuel. car runs a little better but its not running how its supposed to. i have also checked fuel regulators they hold vacuum and fuel pressure is 57 psi to the first regulator from fuel pump.. where should i go from here?
injectors probably need cleaning, balancing after sitting for 10 yrs.. Search here for recommendations on who does this. I would think you should flush the lines. And probably replace the rubber lines. I'm guessing whoever let it sit that long did not change the lines from original.
Team Owner
replace the Idle control valve and O2 sensor and the MAF
