928 Forum 1978-1995
Sponsored by: 928 Specialists
Pressure plate exploded
Old Jul 29, 2018 | 11:23 AM
Tampa 928s's Avatar
Tampa 928s
Default Pressure plate exploded
83
Found only one finger in place and 4 in the bottom of the bell housing the rest are probably on the road.
When taking it apart I found someone spot welded the rear small shaft clamp and now I can’t move it back enough to drop the clutch. I’m going to try removing the rear clamp unless someone else comes up with a workable solution.
Fingers gone
Look at the bent Cps pins
Spot welded
Old Jul 29, 2018 | 11:34 AM
Jerry Feather's Avatar
Jerry Feather
I think that is a factory tack weld.
Old Jul 29, 2018 | 11:38 AM
DR's Avatar
DR
Rennlist Sponsor
You don't see that everyday! I don't think that weld will cause the problem you think it will. Don't let that slow you down!!
Dave
David Roberts
2010 Jaguar XKR Coupe - 510HP Stock - Liquid Silver Metallic
928 Owners Club Co-Founder
Rennlist 928 Forum Main Sponsor
www.928gt.com
928 Specialists on Facebook - 928Specialists
Sharks in the Mountains on Facebook - 928SITM
Old Jul 29, 2018 | 11:58 AM
Tampa 928s's Avatar
Tampa 928s
I feel better never seen that before just tight and has not moved did not want to beat on it.
Old Jul 29, 2018 | 12:26 PM
jcorenman's Avatar
jcorenman
Your pictures show the clamp screws still in place-- they both need to loosened and removed before that coupling sleeve is going anywhere. The front one fits a groove in the short-shaft and must be removed for sure, the rear one will try to get itself into trouble so remove it also. And both need replacement, available from your favorite parts vendor.
Old Jul 29, 2018 | 12:39 PM
Jerry Feather
I see it every time I look at this 928 auto flex plate clamp. It has however broken loose on this one.
Old Jul 29, 2018 | 01:57 PM
Constantine's Avatar
Constantine
To Tampa 928s,
As other have said, that is a factory spot weld. Given the condition of your clamp, your drive shaft and clamp might be rusted together which will make moving it back very difficult. Suggest using a generous amount of liquid wrench or other oil penetrant in the clamp and drive shaft union, letting it soak and then pry it back carefully with a pry bar. Be careful of the aluminum bell housing, use a piece of wood to pry against. Leave the rear clamped, since you could move the drive shaft backward through the bearings if you don't while trying to pry the front clamp rearward.
Good luck!
Old Jul 29, 2018 | 02:44 PM
Tampa 928s's Avatar
Tampa 928s
I have removed the bolts picture was when I started.
i need a few more Mm to remove the short shaft any hints?
Need a few more Mm to remove
Old Jul 29, 2018 | 03:35 PM
Constantine
Looks like your drive shaft migrated forward a bit in the torque tube and is now resting against the short shaft.
Loosen the rear clamp and pry back on the drive shaft to move it back in the torque tube bearings the needed amount.
Old Jul 29, 2018 | 08:19 PM
Kevin in Atlanta's Avatar
Kevin in Atlanta
Correct
Old Jul 29, 2018 | 09:00 PM
Tampa 928s's Avatar
Tampa 928s
One clutch received a little side damage PP nothing remains and Tob can’t even be rotated.
Old Aug 2, 2018 | 07:01 PM
Tampa 928s's Avatar
Tampa 928s
I want to verify the position of the of the preload washer 16 and thrust washer 12 since it was all in pieces when I received it.
Part 16 does it locate in front of the pressure plate does not seem correct seems it should be in the rear.
This is how I believe it should be installed
Assuming flat portion of thrust washer is face down as shown. Preload washer fingers beveled facing up on thrust washer then snap ring
Old Aug 2, 2018 | 07:34 PM
jcorenman's Avatar
jcorenman
You've got it backwards. It's a pull-clutch, and the heavy washer #12 is what exerts the force against the PP diaphragm-spring fingers. So the spring-washer (15) goes on the bearing side-- below the PP diaphragm spring in your photos-- with the teeth oriented towards the bearing. On the top side (as shown in your photos) the heavy washer (12) goes on with the rounded side against the PP fingers. Then the snap ring (11) to hold it all together. As the clutch actuates (disengages) the release bearing pulls the center of the PP spring (downwards as pictured in your photos) via washer 12 and snap-ring 11.
Don't forget a light coating of hi-temp Optimoly grease on the splines, and also on the PP spring fingers where they contact washer (12) and the edge of the spring-washer (15).
Old Aug 2, 2018 | 10:45 PM
Speedtoys's Avatar
Speedtoys
