928 Forum 1978-1995
Sponsored by: 928 Specialists
INTAKE BOOT R AND R
Old Jul 16, 2018 | 11:49 AM
WALTSTAR's Avatar
WALTSTAR
Default INTAKE BOOT R AND R
I am planning on installing a replacement set of intake boots and would like to know if there are any tricks to doing so. Should I cut off the old boots or grease/remove them? The existing are original but do not leak.
Old Jul 16, 2018 | 12:49 PM
Speedtoys's Avatar
Speedtoys
You..simply pull them off after losening the clamps?
Old Jul 16, 2018 | 01:41 PM
WALTSTAR's Avatar
WALTSTAR
Wow, is that all?
Old Jul 17, 2018 | 11:00 AM
joejoe's Avatar
joejoe
Oddly...for a 928....yes.
Old Jul 17, 2018 | 11:15 AM
hacker-pschorr's Avatar
hacker-pschorr
Administrator
16V
1. loosen up all 16 hose clamps
2. Push the rubber couplers onto the runner
3. Loosen the hose clamp under the plenum holding the rubber boot on the TB and Plenum (two clamps, but only have to loosen one)
4. Pull off plenum
5. Reinstall in reverse
Good idea to buy all new clamps too, including the two that go on the TB / Plenum end and that rubber boot too. 928 International, 928's R Us, and 928 Specialists carry what you need.
Have a multi-meter? Check the idle and WOT switch
Good time to change the O-ring which seals around the AFM in the lower "U" piece.
Speaking of the lower "U" piece, that is bolted to the block in three locations. A wedge of rubber with two studs sticking out. There is a good chance one if not all three are broken and the "U" is loose. Getting these studs out of the block can be a real challenge.
Old Jul 17, 2018 | 03:47 PM
WALTSTAR's Avatar
WALTSTAR
The responses in the beginning were obviously addressed to some guy that doesnt know how to open the hood.....
What I was looking for is stated just above.
Thank you Hacker-Pschorr.
Old Jul 18, 2018 | 11:16 PM
j.kenzie@sbcglobal.net's Avatar
Yeah, I dreaded removing those boots. When I first did it, they were no real problem. I did purchase new boots, and I have since removed and replaced them many times. An electric wrench really helps. The rubber has stayed soft, and just slides back out of the way very easily. I kept my old clamps.
Good luck,
Dave
Old Jul 19, 2018 | 12:02 AM
The Forgotten On's Avatar
The Forgotten On
Unless your clamps are corroded or damaged reusing them is just fine.
Old Jul 21, 2018 | 03:56 PM
WALTSTAR's Avatar
WALTSTAR
Default Really?
Originally Posted by Speedtoys
You..simply pull them off after loosening the clamp
Have you a different intake that allows that procedure?
Old Jul 21, 2018 | 04:07 PM
WALTSTAR's Avatar
WALTSTAR
Default Yuop
p!
Exactly what I did.
Old Jul 21, 2018 | 04:09 PM
WALTSTAR's Avatar
WALTSTAR
Default Uh. nope/
Forgot to mention removal of the spider...
Old Jul 22, 2018 | 02:28 AM
Speedtoys's Avatar
Speedtoys
Silicone?
Old Jul 22, 2018 | 12:23 PM
WALTSTAR's Avatar
WALTSTAR
Yes.
Old Jul 23, 2018 | 03:18 AM
Speedtoys's Avatar
Speedtoys
The blue is cool, but considering the location...a massively fuel laden environment.
It’s important to understand how oil, gasoline, and petroleum-based products interact with silicone. These products break down the molecular structure of the silicone, and can cause it to weep, leak, or rupture. Good results may be found if they have a fluorocarbon and fluoro silicone liners. (Flextech.com)
Im no greenie, but silicone hoses/vacuum lines are the next worst thing to clean air than removing the cat...they weep so many hydrocarbons. Those will get..odd over period of time, an odd cleaning cant undo.
Old Jul 23, 2018 | 09:02 AM
SeanR's Avatar
SeanR
I’ve tossed a few sets of those away and replaced with stock. Once they get oil soaked they slip, fail to seal and cause all sorts of issues. Same with those crap silicone coolant lines the 944 guys love.
